I wanted to view a 3d model in raytraced mode with a clipping plane.
I downloaded Rhino 7 trial to try out the new possibility to view it so that the model is even sectioned in raytraced.
The clipping plane does hide some geometry, but oddly enough not all.
Some geometry is displayed as “leftover” artifacts…
Same goes for other views (like front view).
Is the model just too complex/ my hardware not good enough?
Thank you in advance!
PS: I have Intel(R) Core™ i7-9750H CPU @ 2.60GHz 2.59 GHz; Quadro T1000 GPU; 16 GB ram
Ah, thank you!
Do you know of some workaround/ what is causing the issues?
I tried deleting most of the model not showing up in the view but I still have the problem with the remaining geometry.
