I have got a pretty good section of my design with clipping mask, is there a way to export this because if I rememeber correctly making 2d of the clipping mask does not work.
Best,
D
Best,
D
Hi @diana.daoud
If you’re on V6, clipping planes and Make2D work just fine. I’m not sure about V5.
-Jakob
thank you, Jakob!
what about project a line where the clipping plane is placed?
Hi Diana - if you mean you’d like the curves from the clipped objects, try:
Start IntersectTwoSets
Select all the objects as the first set of objects, Enter, then type “IP” (for InfinitePlane) and Enter and select the clipping plane and then Enter again to use the IP as the second set.
If you have not, you might also want to look at SectionTools > https://wiki.mcneel.com/labs/sectiontools
