Clipped drawings not showing as black
Hi
I am having trouble with Rhino 8 WIP
I have created a drawing from a clipped plane section but it is has inherited it colours from the model and I can’t get it to turn black for printing from paper space.
Previously in Rhino 8 drawings just automatically turned black when they were created.
Any help would be appreciated Claude and Google ai just going round in circles.
Thanks
forum problem.3dm (3.8 MB)
Hi Stephen -
You have set the clipping drawing to get the properties from the input objects. You can double-click on the clipping drawing to edit it and pick “By output layers” from the options for that setting:
Hi Wim thanks for your reply, I am half way there. It now will not show the section boundary line as B&W. I imagine this is a boundary line color button or something like that? Also it is not showing lineweights in Print display?
forum problem.3dm (3.7 MB)
Hi Stephen -
Yes, the section properties are defined in the section style. You have defined the “GS 1” style as follows:
The two boundary color pull-downs let you set that color for display and print.
Running UpdateClippingDrawings on the drawing block made that go away here.
