Cleanup Conundrum
In the below condition, I can get A or B, but I need C. Rhino 7.11.21293.9001, 2021-10-20
Va 2.12.0.15100 2021/07/21
Condition 1 is the sill intersection with the angled pilaster, and condition 2 is to hide the seam between the finish and the wall core in plan view of the wall. The objects are attached.
CleanupConundrum.3dm (1.0 MB)
I haven’t found a way around this yet.
Hi @djhg, set the “cleanup radius” property of the walls to “0”.
First, extend the wall that hosts the windows a little bit so it hits the other wall. Then change the cleanup radius to 0.
You may also need to use the vaSubtractSolids command to get rid of some part of the wall, if you want.
Wall Join
