I have a really odd problem trying to get some walls to intersect nicely on a split level house with a raked wall coming in and meeting with two different wall styles.
I tried adding solids command to just “make” it look right, but the lines ofthe edges of the original walls remained visible.
Hi Jackson, it looks like one wall is being intersected by another undesiredly. Try to select both and change the join to “None”. Or send us the file to visualarq@asuni.com and we will check for a solution.
