I adjusted a box by extrusion. I got internal edges and some extra isocurves.
How can I rid of theses edges and get a “clean” box
thanks
Dear Reymond
did you check _moveFace or _scale1D to do the adjustment ?
to clean the result you might want to try:
_mergeFaces
or delete single Face and
_cap
or
_explode
_rebuild (Point 2x2, Degree 1x1, DeleteInput=Yes, Retrim=Yes)
_join
hope that helps
best
tom
no, I did a ExtrudeSrf
I tested the MergeAllFaces to clean, looks better
No more internal edges.
I still don’t understand the way the isocurves are generated. Vertical isocurves are well distribued, the horizontal surfaces seem odd.
Hello - it looks like `MergeAllFaces might help. If the faces are planar that should clean up some - how are these made?
this is just what I made. Result looks good. About the faces, they were just an extension of the basic faces of the box (ExtrudSrf), so they are planar.
My last question was avbout theses horizontal isovurves that seem to be distribued by hazard
