hello all i am trying to design double skin facade of diamond panels with perforated circles and while i am using ruled surface order, the design of the circles are on the facade without subtraction.
I can’t make perforated circles for diamond panel surface.
try this
remember to graft and simplify both merge inputs, and flatten Boundary Surfaces output
next time please attach a GH file with internalize geometries, so we don’t become professional photoretouchers but can keep doing GH stuff
thank you my friend i have done what you told me. It is amazing solution but i got problem fo honeybee solution .
the file is attached
parametric facade.gh (147.7 KB)
what error appears if you click on the red baloon of the error component? I don’t have honeybee .___.
- Solution exception:There must be at least 3 vertices for a Face3D hole. Got 0
I literally have no idea, but googling it looks like it might be a tolerance thing?
if you want to give it a try, open rhino properties and put some more zeroes here like 0.00001
then go back into GH and press F5 to recompute the solution (or right click on canvas → recompute)
another thing I would try is to Mesh Brep
the Panels, and use the meshes instead of Breps
thank you too much Inno for your help but this solution did not work with me.
I think it might be the case to post this on the Ladybug/Honeybee forum then
