Eliel
(Eliel)
March 13, 2020, 11:07pm
#1
Hi guys! i have no idea how to resolve this matter.
I am currently trying to generate a definition that pretty much allows the control over a helix; the idea is to vary its diameter
, and its helix pitch
through the Graph Mapper component.
I want it to have a smooth, continuous finish where it starts and ends, just like anywhere else on the helix.
Circular_helix.gh (9.7 KB)
maje90
(Riccardo Majewski)
March 13, 2020, 11:36pm
#2
Your “Series” component, at input parameter “C” , remove the expression and it’s fine.
Eliel
(Eliel)
March 14, 2020, 12:45pm
#3
sorry but the problem continues. also a single turn shouldn’t go that many turns. I’m sure something is wrong
maje90
(Riccardo Majewski)
March 14, 2020, 1:03pm
#4
Remove the reparametrize on you Evaluate curve component (that orange one).
Why you made that change?
Eliel
(Eliel)
March 14, 2020, 1:12pm
#5
ok my mistake, i also try to create a closed helix with variable radius and variable pitch. within the main definition.
something like this image
This is an old answer of a question like yours
helix3.gh (15.2 KB)
Eliel
(Eliel)
March 14, 2020, 4:05pm
#7
I just don’t understand why it fails
Circular_helix.gh (18.5 KB)
Hi Eliel,
I don’t know either but you can try this one. Each of the sample circles gets a sample point after 1/4 of rotation. Helix is getting a little bit more exact by increasing the density parameter.
Circular_helix1.gh (13.6 KB)
Hth
Ferry
Change the radius , i don’t know why that happend, and search in the forum i am sure there is a thread with many solutions
Circular_helix2.gh (20.8 KB)
Eliel
(Eliel)
March 14, 2020, 5:11pm
#10
thank you all that if it worked.
@seghierkhaled I didn’t use your first solution because it was heavy on my pc
Check this as well
Circular_helix3.gh (10.6 KB)
Eliel
(Eliel)
March 14, 2020, 5:36pm
#12
I’ve been testing it but that little distortion in the end persists
Of course you must do improvement, and you can find more simple solutions.
And never change this it is 360 degree
Circular_helix3.gh (9.7 KB)
Eliel
(Eliel)
March 14, 2020, 5:47pm
#15
Thank you very much, I am studying all this to learn more
Eliel
(Eliel)
March 14, 2020, 5:48pm
#16
@HS_Kim Thanks for adapting the Graph Mapper component, I was thinking about how to do it :sonrisa:
