Hello everyone
im attempting to create a circular brick pattern on a dome like surface, by using preferably only standard format bricks
the main two problems im facing is the intersections between the bricks, which gets increasingly more noticable the smaller the curve is, but if i attempt to solve the problem by increasing the spacing between them, the angle of the joint will surpass the minimum tolerances.
brick dome circular.gh (29.8 KB)
its possible to follow the geometry better by splitting the bricks into discrete elements when its needed
but it is not always required, and since my objetive remains to maximise the amount to bricks of the same dimensions, i wanted to figure out a logic that uses the angle of the joints to determine if its within tolerances and act on that
since im new to grasshopper, im unable to figure it out, and naturally there may have been a much easier approach to mine.I wonder if there is a solution or a similar problem.
