Hi there
I have this definition of a simple circular wall of bricks. The idea is to have an intercalated pattern, one horizontal and the next one rotated in 90° (flemish bond). I think the definition works pretty OK; but when I try rotating in 90°, half of the circle rotates to the exterior and the rest to the interior. Till this point I really do not know how to solve this, I would appreciate any help with it! Thank you!!!
Bricks_try.gh (13.3 KB)
Align the planes with vectors from the center of your circle to the planes.
All x-vectors pointing outwards in my screenshot…
Bricks align planes.gh (18.6 KB)
Hi Martin, thank you so much for your help
I checked the definition. I could reach the same result by using the construct domain rectangle, meaning that the bricks are created from the centroid. But what Im trying to achieve is that the 90° bricks, needs to be aligned with the edge of the horizontal brick. Trying this, created half of the bricks flipped, so my aim is not to align all of them from the center.
But this is solved, right?
Maybe to clarify what you want to achieve you could assemble a few bricks manually and post a screenshot of that?
Hi! Yes, indeed I fixed it, but thank you so much for your input, I was missing that little part of aligning the planes to the centroid. ty!
