Circles in Rhino 7 disappear upon finishing command
Win10 Pro 20H2
Rhino 7.1.20343.9491
Currently I am having an issue where I’m not able to draw circles.
Specifically, the circle dissappears when executing final step.
No geometry is made. (checked by trying to “select all”)
Any solving help regarding this would be greatly appreciated!
Please run the SystemInfo command and post the results.
I suspect you are running an old defective OpenGL GPU driver.
And please assign your posts to the appropriate categories and stop posting the same message repeatedly.
Thanks
Could be.
Using a laptop that is getting old (2013-ish), by todays possible standard.
Give me a few sec
Sorry about the double posts. I just got a bunch of errors, and noticed that it went though anyway ;S
Weird.
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: Commercia, build 2020-12-08
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel® HD Graphics 4000 (Intel) Memory: 2GB, Driver date: 12-27-2018 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GT 740M (NVidia) Memory: 2GB, Driver date: 4-9-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 425.31
> Integrated acclerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-9-2019
Driver Version: 25.21.14.2531
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\5.0.1.0\XNurbsRhino.rhp “XNurbs”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
If it’s that old, your laptop most likely does not meet Rhino V7’s System Requirements.
Here’s a link with great advice for getting a good replacement system:
Your display drivers are both old.
1 - Your display drivers are more than 2 months old , update them manually.
The automatic driver update tools have a near 100% failure rate .
Use these links instead:
2 - for " Hybrid " graphics systems like yours, make sure your Nvidia card is " primary " for OpenGL
  • NVIDIA
  • In Windows Control Panel > Power, choose High Performance , not Balanced or Battery saver.
Was hoping to be able to postpone buying a new laptop until 2022.
Everything has been going fine until recently…
But I guess I was going to hit this wall sooner or later.
The GPU drivers… indeed. Haven’t seen any updates from Nvidia lately… ;S
But is it really likely that a driver update alone suddenly breaks the circle command?
No. What broke the display is almost certainly a Windows update.
The fix is usually updated display drivers.
Do not use any of the automatic driver checking tools.
They have a near 100% failure rate and will tell you your drivers are current when they are not.
Use the links I gave you instead and find the current drivers manually.
but then selecting the geometry should still be possible?
I mean it’s not just a visual thing. The geometry is not being made.
It’s like like the circle command is never “finished”.
The last nvidia driver for my laptop was updated in april 2019 :smiley:
Let’s get the drivers updated then see if there is still a problem.
You might have a Selection Filter problem as well compounding your confusion.
Im also fully able to make an elipsis and everything else…
Just not a circle
Can you see the 3 circles in the file below?
3Circles.3dm (317.7 KB)
I sure can.
Can’t follow up much more on this topic today though.
Got to get myself some food, before I end up devouring my laptop instead.
OK, so it seems possible that it’s not a display problem then… odd.
Check back in when you have gotten something to eat…
Sorry for the overly late reply Helvetosaur.
Well, here is an unforseen update to the issue.
I started my laptop again this evening, to have a look at the issue at hand.
Weird, but true; The problem seems to be gone.
I’ve been scratching my head regarding this one, because there has been 0 changes on my laptop since last i wrote.
Oh well… If it works, I guess it works.
Although this is a bit of a jump, I’ve noticed a different issue when using Rhino 7.
Copy/Paste seems to be incredibly slow. Read somewhere in the forum that the issue would dissappear when deactivating OpenGL in “Display Pipeline Assignment”… That seems to be the case for me as well…
Heard anything regarding this?
I think they’re working on a fix for this…
