Topic has been brought up a few times. Checking Drag selected objects only does not fix it.
Will explain again. While moving the mouse pointer with shift pressed to select a second object from the Choose Objects popup menu, it starts dragging the first object you had selected.
Solution for this is releasing shift while selecting the second object from the list. Would be easier though if you can keep having shift pressed and it only starts dragging after a second object has been selected.
