Check if photo reference is scaled or not?
I imported a few images as photo references (picture command). I scaled one of them (scale1D). I don`t remember which. How to determine which is scaled without reloading everything? How to reset the scale of an imported picture to the base dimension?
In principle you cannot, since Rhino doesn’t store these transformations. If however your pictures have a known aspect ratio, it should be possible to make a script to detect it
Thanks
_Picture attaches the image to a Plane Surface. If it is non-uniformly scaled, the surface will be converted to NURBS. Therefore, use _What to check the surface type.
Hi @mdesign
here a simple check with python:
picture_id = rs.GetObject("Select Picture")
if picture_id:
    u,v = rs.SurfaceParameter(picture_id, (1,1))
    pts = rs.SurfacePoints(picture_id)
    x = rs.Distance(pts[0],pts[2])
    y = rs.Distance(pts[0],pts[1])
    if abs(u/v - x/y) > 0.01: #tolerance
        print ("picture scaled non-uniform")
    else:
        print ("picture is proportional")
Brilliant!!
