Unable to change units from centimeters to feet
I do it in the settings window but it does not change when I analyze a distance.
are you using the _Length command when analyzing distance?
if so, run the command with no pre-selected item then you’ll be given a choice which units you’d like the length to be displayed in.
the setting will remember itself throughout a session so after you set it once, you can then go back to pre-selecting the curve(s)
Hi Bernard- that depends on how you deal with scaling - if you say Yes to scaling, measuring should work out. I did notice that the default page for Units was set to Layout and not Model, and it looks like nothing changes - make sure the Model page is the active one in the Units settings.
