When changing units (ft, meters, etc) in a document, it used to ask me if I wanted to scale the geometry in the document to match the new units when I wold change it? Now it doesn’t for some reason?
Is there a way to get that dialog back? I don’t want to look up the scale factor and manually scale the whole model each time I change units? Is there a setting to bring that back? Is this some intentional change in V7.16? If so, it is not a positive change.
I am still having the same problem in rhino mac. It says I have the latest updates Rhino 7.16.
In the link above that Pascal sent it mentions a rhino 7.17 will fix it. Is this available for Mac, or is there something else to check to restore the unit/model scale change?
Hello- if you set Preferences > General > Updates … Update frequency to ‘Service release candidate’ you can get at the latest publicly available build.
