I’m trying R9 WIP. BETA
(9.0.26223.12303, 2026-08-11)
I started a new file and imported a .stl object in on the Default (Black) layer. If I change the object to a different layer, (Layer 2 Red) the properties in the panel change to that of the new layer, but the color of the object itself remains that of the layer it was originally imported onto. I tried different stl files, and different layers. No matter what, the object retains the color of the original import layer.
Does the object have a ‘color by object’ override applied?
After a restart it seems to be working normally now.
But in case, where is “color by object” located? It’s not under “Display Color” properties.
It’s labeled as “Custom”.
This problem is here again. However, I opened in RH8 and it was there too. Obviously it’s something I’m not setting correctly when I import the .stl files. All these are on the layer Collets which is set to Magenta. Yet all the collets remain in the default color. The properties below are for the selected collet.
What am doing wrong?
The content of your blocks is on a different layer
