Changing material color in keyshot
I’m a beginner user of keyshot and bumped into an issue.
I need to change the color of the wood (see attached) to vivid yellow, and then put the render in an environment (mockup).
How do I change color of a material?
Hi @Eszter_SMid
This is not really a Keyshot forum, but anyhow: Go to the textures tab and select your diffuse texture. Almost at the bottom of the panel there will be a “Mix with color”. turn it on that and change the color to mix with to yellow, so that it looks like your reference photo.
HTH, Jakob
