HI everyone,
I have a 3D file with different objects in it, and I want to make a render in keyshot. But I don’t know how to diferenciate every pieces in rhino? should I apply a texture in rhino, or should I make a different file with every pieces?
Thanks
Hi Paul,
Do you mean that the objects once in Keyshot can only have one material? I recall something like this in previous versions but I thought that the issue no longer occurred. Try placing the objects that should be different materials on separate layers in Rhino prior to going to Keyshot if I’m correct in assuming the problem.
