Material color
When I first applied this material, the color was correct. I’m not sure what I did, but now the color has changed to this blueish-grey. I’ve been trying for a while to figure out what I did and get it back to the tan color, but I cannot figure it out. Any help would be much appreciated. Thanks
It’d help if you could share the file with a surface that has this texture. You can attach it in a reply.
when i exported just this surface, i realized that the underside is the correct color, and then i realized it was using the custom environment for lighting that turned it blue, but i can’t upload with the environment bc the file is too big
