Is there any possibility to transfer a lot of hatches into surfaces in order to extrude them?
Otherwise i have to join all the outer curves an fill the areas in between which turns out to
take a lot of time! And there is a lot to do… .
Select all the hatches and call _DupBorder. Then, with the borders still selected, call _PlanarSrf. you can then use _ExtrudeSrf to extrude the surfaces.
SOLID hatches, I meant, so whatever type, scale and angle of the hatch you have you can change it to solid hatch with a single click at properties panel. Exploding changes them into surfaces.
