Changing "Get Geometry" Settings Takes Way Too Long - Update Request
It takes me 30 seconds to ensure only polysurfaces will get selected during this command. The menu needs to stay there so that I can not only deselect quickly but also ensure that I have the correct options selected. Any chance this issue can get solved?
Try RMB click one type
Okay wow thanks that really helps a lot. Had no idea this was a thing!
Yes, this RMB-click works also for osnaps and selection filters in rhino. Repeat the RMB-click to revert to the previous state. (repeat-click to revert only in rhino, not grasshopper).
Thats awesome, this will help a lot when using selection filters. Thanks!
Are these native GH tools? There’s no associated help & neither does CTRL+ALT show where the node is located.
Hi Frank -
Yes, they are.
You can find them on the `Params → Util tab.
I’ve created RH-83564 Grasshopper: Util>Get Components Location and Help
