Change the shape accordingly the gradient map
Hi
I would like to change the shape of the flowers accordingly the gradient map. (not scaling).
I mean that in the black area of the map, the distance between ‘CP’ and points will be bigger then in the white area.
I think maybe the second number (that I marked) need to be construct domain?? but I really don’t have idea how to do, I would like your help.
Many Tnx !!
File?
seamlessBra_pattern_210419.3dm (761.2 KB)
seamlessBra_laces_210419.gh (34.6 KB)
I am very happy for you help!!
I really need it… thank you :slight_smile:
Something like this is what you want? I used pufferfish plugin’s Pinch’n’Spreadfor convenience.
seamlessBra_laces_210419_re.gh (26.8 KB)
Hi thank you very much on your answer.
Yes kind of, but I would like that the shape will change accordingly to the map … you can do it ?
I don’t understand what you mean.
@HS_Kim super cool!!!wow
I would like that in the black area of the map the radios of the Pinch’n’Spread will be bigger and it white area the radios will be smaller . that more clear?
Check the linked topic bellow.
seamlessBra_laces_210419_reV3.gh (24.7 KB)
HI @HS_Kim THANK YOU VERY MUCH!!!
it is perfect…! :blush:
