Hi all,
Is there a way to change the default save location for settings data during the rhino install process? I mean the location of this folder: %APPDATA%\Roaming\McNeel\Rhinoceros\6.0
Reason is that our system administrators have set a users %APPDATA% folder to a network location (which for laptop users is also synced using MS Sync Center). This unfortunately makes Rhino extremely slow compared to standard local installs.
I noticed that in Rhino → Edit → Options menu there are quite a few folder paths which point to this location, so manually altering all of these is very time consuming.
