Hi Guys,
Found an unexpected issue with an unroller component when moving a def from R6 to R7.
This is what I see from my def in R6 once I have unrolled some parts and spaced them out:
Then when I open the same def in R7 the panels are unrolled to a different location:
The part of the def I’m seeing the issue in is attached with some sample geometry internalised.
I have tested with a few different ‘unroller’ components, but they all show the same change between R6 and R7.
Was there something changed in the unroller class between these two versions?
Cheers
DK
210828_Unroll Class Changes.gh (219.0 KB)
