Unroller bug?
I found a little problem with Unroller class.
If I write that everything is working well
Unroller unroll = new Unroller(brep);
unroll.ExplodeOutput = false;
Curve crvs;
Point3d pts;
TextDot tDots;
Brep breps = unroll.PerformUnroll(out crvs, out pts, out tDots);
A = breps;
But if I write that, there is no output in breps ? The number of unrolled breps is OK.
List breps = new List();
int num = unroll.PerformUnroll(breps);
A = breps;
B = num;
Does I miss something ?
Here a GH script showing the problem
unroller_bug.gh (86.2 KB)
Hi @laurent_delrieu,
I believe what you are seeing is just how the List component reports Breps with a single face.
– Dale
I don’t understand. The list is empty and the method indicates that 67 faces were flattened.
There are 67 faces in the array.
Ah yes - thanks for pointing that out.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44294
– Dale
