Change command default options
Is there a way to change a command’s default options? In particular, when I use the ‘Insert’ command to insert a block into Rhino, the default option for ‘Block definition type’ is ‘Embedded’, but I’d like the default option to be ‘Linked’, so that I never make the mistake of using ‘Embedded’.
Attaching image for reference.
Thanks!
Juan
Hi Juan -
You can make a macro that sets the link mode and put that on a button or an alias.
Hi @wim ! Thank you very much for your response.
Would you mind being a little bit more descriptive about how to do it? I’m not very savvy in this area and would appreciate some help. Maybe filming a quick video or screenshots would be really helpful.
Thank you!
Juan
Hi Juan -
I don’t have a PC available at the moment.
Just start the Insert command with a dash in front -Insert and follow the prompts on the command line. When you have like a file, look in the command history and copy the keywords into a single string in the MacroEditor.
Got it, thanks Wim!
