Insert Dialog defaults - Rhino 6
In Rhino 5 the dialog for insert→ Insert As → Option would stay the same as your last selection.
Rhino 6 always defaults to “Block Instance”. Is there a way to make Rhino 6 default to “individual objects” -or- your last selection?
Hello - looks like a bug to me - thanks for the report.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44370
I use drag & drop to insert models and the “block definition type” is not sticky either. I almost always use “linked”. In Rhino5, the type was sticky but in Rhino6 it isn’t. Always reverts to “embedded”.
