Certain files not opening post recent update
Hey all,
Don’t know if this is anything you’ve experienced, but… Essentially I can’t open one of my templates after updating rhino 8, and the kicker is I can’t open any of the files I created with that template. I can open up a fresh file with one of the default templates no problem. But anything related to this template just causes an endless loading screen, not even an error.
I’ve even tried importing the problem file into a fresh file, but it still creates endless loading. These are files I’m thankfully no longer working on, however would be great to go back to reference. Also annoying because I don’t want to have to go through the process of making my template again when I’d got it perfect!
Any help would be really appreciated
Katie
Hi Katie,
This odd, by chance there materials in your template that are referencing hosted resources?
Can you post or send us your file? https://www.rhino3d.com/upload
Hey Japhy, thanks for the reply. I have just uploaded one of the files that wont open. I don’t believe it references any hosted resources. Let me know if you can open it- I can send the original template as well if this would help
I don’t have access to my mac at the moment (in the middle of workshop actually), when opening in windows i get several missing fonts as well as image resources. I suspect that is where it is getting hung up.
Ah yes, a hangover from older versions of the template… Is there a workaround here? I used to get that notification however it doesn’t even get to that point now- just endless loading… Thanks again for investigating.
I would expect an email from the support team shortly on this, hopefully they will have additional details shortly.
I won’t be able to look at this on my mac till later.
Thanks again, think I’ve found a workaround. I have tried on my partner’s mac and he can open it no problem. My mac has lower specs, but before the update it was opening this file fine. Strange! Anyways, when he saved it as as a Rhino 7 file and sent it back to me, I was able to open no problems. Saved as Rhino 8 file and again no issues. So odd… Have all the files again and all working - had to create a new template though.
Hello, this happened to me today. My project file is impossible to open after the last update, but I can open all of my other files. My colleague was able to open my file, but then her Rhino also did the last update - and then she got the same problem. Help! Using Rhino 8 for Mac
Hi Ingrid D,
Please run SystemInfo in you Rhino command line and post the results. Can you post or send us your problematic file as well?
Hei Ingrid -
Thanks for sending that file.
It opens here on 8.27 on macOS after a long time and then “beachballs” substantially when navigating the scene. It works fine with the same version on Windows so I’ll get that filed for a developer. I’ll PM you a link to 8.26.
RH-91808 Performance Issue SR27
I am having the same problem. After the update all files take forever to open and every tool I use, beachballs appears. Do you even try the versions before you release them? It is absolutely impossible to use Rhino now. How do I get back to the previous version?
Hi Mikel -
I’ve sent you a link to 8.26.
