I I am having a problem since about a month age with Rhino. files take really long to open (not big files, around 100mb), and sometimes it just freezes and the file will never open. once its open, and I try to render anything (I use VRAY 2) it freezes again.
I just discovered that if I disable the network connection, everything works fine. any idea of what could be causing this issue?
PC specs:
Windows 7 professional
Intel Xeon E5620 dual processors 2.40 GHz
24GB RAM
ATI FirePro V4800 graphics
Not sure if this will help but I had a similar issue with Rhino hanging on start. Turning off the internet solved it for me as well.
The problem in the end was a plug in trying to call somewhere that did not exist. I figured it out by watching the startup screen and noticing which plugin was being loaded when the problems started.
Also when Rhino did finally start up I had an error in the command line for that plugin amongst all the normal stuff.
If you block Vray, and other non-default plug-ins, (options > Plug-ins page, > Enabled check boxes) per plug-in, and open the same files, does that make any difference?
ok, I tried disabling the plugins at start up (VRAY and Badger), the only two plugins I’ve installed since I re-installed everything yesterday. same problem.
when you open Rhino for a new project(not a previous file), it will load fine with the plugins. if you try to import or open a file once rhino is open, the same thing will happen, it will stay there for a long time.
Hello. Something you can try since all else seems to fail…
I prefer doing my own updates and not having the McneelUpdate Service running constantly in the background, so I disable it using a free Microsoft program called AUTORUNS which can be downloaded here: http://technet.microsoft.com/en-US/sysinternals/bb963902.aspx
You don’t have to install Autoruns.
Just unzip the files to a folder and run the autoruns.exe file from the folder.
Once open, Autoruns lets you see every program that is set to start with your system and additional services. Be careful in this program!
Click on the Services Tab and Un-Tick McNeelUpdate. Close the program and restart windows. If you need the service again you can re-tick it and reboot.
Autoruns works ok Xp, Vista and Win7 and probably Win8 too.
Check that your firewall isn’t blocking McNeelUpdate, or Vray, and allow 127.0.0.1 through your firewall. I had lots of trouble getting Vray to render, even on single machine, until I found a setting on Comodo Firewall that was filtering loopback(127.0.0.1). Vray requires access to this IP loopback even if you’r rendering on single machine. I disabled 127.0.0.1 filtering in my firewall and Vray started to render perfectly.
Hope this helps. Michael VS
Since this problem exists on your local computer, even in safe mode, it should be possible for us to reproduce in the debugger here. Please upload the file to me at http://www.rhino3d.com/upload?to=brian@mcneel.com
when I start a new empty model it loads just fine, its when I try to open a file, either by clicking on it or by opening or importing it from within rhino.
