Hi Guys!
I need to model a nurbs surface with a cell-like-structure with a concave surfaces.
I need to create something like this:
This is create from a height map mesh output. The cell structure I created using filter forge:
Creating this from nurbs does not create a clean geometry and is very heavy…
I then tried to create something by boolean spheres but this result is not quite right:
Any thoughts on how to create something like this in Nurbs? Maybe grasshopper?
After I have a flat surface I will trim it and use flow along surface to create a double bend surface.
Thanks all!
Isn’t the whole point to have “concave (or convex) surfaces”, not flat?
P.S.
https://discourse.mcneel.com/search?q=inflate%20voronoi%20%20surfaces%20order%3Aviews
Having trouble creating an inflated Voronoi script on an surface. I’ve seen how to do this on a flat surface but have not been able to figure out how to apply it to an ungulated one. Currently having the voronoi script correct, just need to be able to inflated each section. image|690x339 [image] VoronoiOnSurface.gh (20.6 KB)
I misused the term planar surface
What I would like to create a cell surface with the concave and then flow it along a surface.
The bubbles plugin looks very promising but cant get it too work.
This kangaroo component appears missing and cant find it online:
Any thoughts on where to find that?
thanks!
Jonas
Are you also misusing the term “concave”?
NakedVertices is under the ‘Mesh’ tab of Kangaroo2, built inti R7. I don’t have Weaverbid required for @HS_Kim ’s Voronoi_Bubbles_re.gh GH code .
Without fully knowing what I’m doing, I hacked a plugin-free version of @HS_Kim ’s Voronoi_Bubbles_re.gh in the other thread.
Voronoi_Bubbles_2024Aug16a.gh (18.0 KB)
It has gaps between the cells, which perhaps are fixed at the end of HS_Kim’s code by the ‘Weaverbird Join Meshes and Weld ’ component that I deleted?
Ow wow… Clearly you know a lot better than I do how to make this work! thanks for trying man
Too bad about this gaps though…
Did you install the weavebird plugi? I believe this is free to download
https://www.giuliopiacentino.com/weaverbird/
