Having trouble creating an inflated Voronoi script on an surface. I’ve seen how to do this on a flat surface but have not been able to figure out how to apply it to an ungulated one. Currently having the voronoi script correct, just need to be able to inflated each section. image|690x339
VoronoiOnSurface.gh (20.6 KB)Your Surface component is empty - you need to Internalize it’s data and re-post your GH file.
Here’s a cluster I’ve been using for quite a while that applies a Voronoi to a curved surface. This file might require GH6, or the add-on that has to do with Voxels - I really don’t recall which it is.
The Voxel related parameters are fairly sensitive, so be careful with changing them.
Make Voronoi.gh (164.9 KB)
please check this one it might give you some better solutions …
VoronoiOnSurface_1.gh (22.6 KB)
