I would like to analyse castellated/ perforated or cellular beams in Karamba. I could not find any cross section types for it in Karamba. So how can I analyse those beams?
Using 2D analysis in karamba? or is there any other effective solution? Please help!
Hello Greatsaiyamandbz,
in my opinion there are to possible approaches with beam-elements:
In case of small openings choose an equivalent web-thickness.
For larger openings use beams which simulate the upper and lower part of the perforated beam and thus constitute a local Vierendeel system. Connect them to the beams forming the non-perforated regions via stiff springs or eccentricities.
Sorry for asking this and late reply. Is that a section or along beam length which you have drawn?
If its a section upper and bottom horizontal small dotted lines represent flanges for I section or you drawn section of rectangular beam? and what does small dotted horizontal lines on outside of vertical lines represent?
it is a vertical section along the beam length.
The dotted lines left and right represent the continuous beam. The upper and lower dotted lines in the middle the parts of the beam above and below the opening. The vertical lines represent the eccentricities or springs which connect the parts.
Best,
Clemens
I was looking in to the same problem to use a Castellated beam in karamba 3d. Did you in the end figure out the way Clemens explains or did you find another way? I am curious to your solution.
