Hi everyone, I have a twisting Poly surface and I need to cap it since it says “open Poly surface”. I applied Cap command to close the open Poly surfaces now I want to know the location of the Cap surface. What command should I use to do such task?
Hi Aida - you can DupBorder on the object before Cap, to place curves there , or see them with ShowEdges > Naked edges. However if you are capping and don’t know where the caps are, it seems like maybe you are trying to fill holes that should not be there, and there may be better ways to handle it.
