Hei for some reason i wasnt able to cap holes the columns. Iam using Ruled surface to combine two surfaces together
Here is the file:
unnamed.gh (21.9 KB)
Thanks for the help!
Here is the file:
You already have the end cap surfaces, so just use brep join to create closed breps.unnamed_ME.gh (22.1 KB)
Thanks, it is working in this case.I made another similar example (Code below) and it was not working:
I don’t understand what you are trying to achieve in the second case.
Is it something similar to this? unnamed2_ME.gh (69.0 KB)
No, I just want to make them also as closed breps. They are just in row. I think you have been deleted some of them or every other element you did.
It is working. Thanks!
