I’ve got a surface that keeps showing a displacement map which despite my efforts to purge doesn’t seem to go away. Selected the surface and went into displacement map and unchecked “ON”, nothing happened. Tried applying a new material, nothing.
The surface and material with displacement was created in V5. What I could see, is that displacement wasn’t visible/working when I opened the model in V6. But, having modified the original surface in V6, it now seems to show the displacement.
No problem attached is a model. Further elaboration: modeled/rendered V5 a while back so a bit hazy on specifics, brought into V6 to rework rendering using Artic display and new material system.
Working in V6 I didn’t see any displacement map when rendering so completely forgot about it, started editing the surface (duplicating/extracting) where displacement was and then at some point displacement seems to start working. Then tried to rid the surface of displacement and couldn’t purge it.
