Can't see my joints
So I am trying to add hinged joints into a portal frame as can be seen in the illustration. When I look into the modelview mode I can not see those connections. Am I using the joint funtion incorrect? Thanks in advance.
joint.gh (182.1 KB)
Hi, you are using the beam joint to create joints between shells. You need to use the LineJoint if you wish to define joints between shells. You can refer to Karamba3D TidBits #20 Line Joints - YouTube
