Hello! In our model we have four types of connections: shell-to-shell (we use Line- joint component for it), shell-to-beam (we use Line-joint component for it as well) and column to beam (we use beam-joint-agent for it) and, finally, we have shell-to-column connection. And we have a problem with the last one, because we don’t know how to set joint in the point node. Can you help, how to solve it?
Hi you can use a Beam Joint or Beam Joint Agent to simply apply a joint at the end of the column (where it connects to the shell)
