Can't see lines
Current WIP, can’t see lines. Curves yes but no lines
Hi @martinsiegrist,
Can you paste Rhino’s System Information here? Help -> System Information....
What is the least amount of steps you need to reproduce the problem? What display mode are you in?
-David
Open a file, draw a line. The line is visible in Rendered mode and I can select the line in any display mode. When switching to Raytraced in the Perspective viewport, the line shows up in the other viewports in Shaded mode but then goes away when I zoom.
System info below:
Rhino 8 SR0 2021-4-6 (Rhino WIP, 8.0.21096.12305, Git hash:master @ 953efa594edf90b45b18f31fb4ef97cc795eec4c)
License type: Kommerziell, build 2021-04-06
License details: Cloud Zoo
Expires on: 2021-05-21
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 10-7-2019 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P4000 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 3-10-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.92
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-10-2021
Driver Version: 27.21.14.6192
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files (x86)\Evolute\EvoluteTools T.MAP for Rhino 6\EvoluteCoutHook.rhp “EvoluteCoutHook”
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.21096.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.21096.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.21096.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.21096.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.21096.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
So you can’t see the line in Wireframe mode unless you’ve selected it? If your Wireframe display mode has modifications, can you please export the display mode settings to a file? After exporting, press the Reset to defaults button. Does it work now?
Even if you just add a line to an empty scene, can you still save the file and attach it here?
-David
No modifications done to the display modes.
A file with one line:
one_line.3dm (26.3 KB)
I see the issue and I’m working on a fix.
@martinsiegrist,
Just a quick check - do you happen to have the tessellation shader disabled? Do TestGLTessellationShader and set Enabled=On.
-David
With this set to On, I can see the line.
Was it set to Off by Default?
I’m glad it works now!
No, it’s not off by default. That’s what’s confusing me. Even so, line drawing should work even when it’s off, so there’s definitely a bug here. I will continue investigating. Thank you for reporting this!
-David
I found the bug which caused the lines not to draw and the fix is going into Rhino WIP right now. I still don’t know why your tessellation shader was disabled. Below are three ways to have them disabled:
  1. Rhino detected that a user is drawing the viewports with an Intel GPU that is using an older OpenGL version (OpenGL 4.3 or lower). According to your System Information, that seems to not be the case.
  2. Tools -> Options... -> Advanced changing Rhino.Options.OpenGL.UseTessellationShaders to False.
  3. Can be disabled using the test command TestGlTessellationShader.
Let’s hope this doesn’t cause any more trouble for you.
-David
Thanks for the info. I have not done anything to the settings
