Any idea why? All vertices are welded. Thanks a lot! H
Spiegeltisch Original - FINAL Pepakura.3dm (398.6 KB)
Hi Hannes - Rhino does not like the mesh - (Check
command) but despite all the bad stuff it tells you in Check, you can clean up using AlignMeshVertices
at .001.
Check! Thanks @pascal, will keep in mind! H
@pascal is it VertCenter ?
2nd question, would that work also for duplicates? Since SelDuplicates doesn’t work on meshes and here in my current model are always 1,2 simliar meshes…Would help me a lot with my current project!
Maybe this old White Paper will be helpful:
http://www.rhino3d.com/download/rhino/4.0/scancleanupremodel
Will download now! Thanks @John_Brock for stepping into this!
