Every time I try to change materials on Rhinoo, it crashes. I can run hefty files, do complex geometry, and use Grasshopper, which is fine. I even run Revit while having my Adobe Illustrator open, and it runs perfectly. However, the second I try to change the email in rhino, it crashes. I originally thought it was because it was a big file, but I did a new template and made a box and tried to change the material, but it still didn’t work. I need to submit a rendering with materials for my class, so what should I do?.
Please try these steps:
i just saw that thank you so much worked perfect
