I can’t change the colour of this pink object. I checked in layers, materials and properties and I don’t know where it’s hidden.
Any ideas?
Thank you
Pls try to run the command RemovePerFaceColors to clear per-face display colors first.
I can’t use this command… It doesn’t let me select anything with command active. If I select object/surface before the command it just doesn’t change anything.
Could you share this 3dm file?
You have “color backfaces” turned on in your display mode and the color is set to pink…
That’s exactly what it was! because I was modifying the surfaces, I couldn’t see anymore my external colour and colour from the inside became my external…Thank you for your help!
