Cannot print to printer from Rhino WIP
As title suggests, having problems printing directly to printer from Rhino7
Job will show in print queue but always “error”
No such issues on rhino 6 when printing with same file.
Thanks!
Assuming your V6 and V7WIP are on the same computer, I don’t understand how that could happen.
Rhino just hands the print job to Windows.
I’m using an old HP InkJet printer on my home network and I’m not having any problems printing from any application.
If you print using RhinoPDF, can you then print the PDF?
Hey thanks for the fast reply!
While trying PDF noticed it will work in raster but not vector (v7)
So maybe bad object? I started a clean file in v7, copied in the model and now works!
(although still weird v6 will print in both raster/vector)
Thanks again for getting me on the right tracks!
Can you print in RasterMode?
What Displaymode is the Detail in; might it be in technical Displaymode?
Can you print when the Detail is in Wireframe mode?
