Hi. So i’ve been having this issue for a while. I am unable to print or save anything as a PDF on rhino. In the regular viewport (perspective, top, left, etc.) you can see the lines and drawings, however when you go to save or print nothings comes out. I’ve tried checking the visibility, adding line weights, adjusting the viewport (maybe I was looking at the wrong place), everything but the drawings just dont come out. I’m not sure what the issue is. please help i have a final soon
What exactly did you check? You should be able to print stuff when you check “Only selected objects” under “Visibility” and then select the objects you want to print before you hit the Print command.
Max.
