A couple of days I installed MacOS Ventura, and then I downgraded to Monterey since it seems it is too early to try. I did a clean install of OS, then used Time Machine to revert back. Since then I cannot open Rhino. I uninstalled and did a clean install with latest file as well but still no luck.
Crash report below:
Translated Report (Full Report Below)
Incident Identifier: D66A7014-F68C-40DA-9F4D-EC99FC35647B
CrashReporter Key: 000410E0-F39B-2EAC-7243-E254033FC785
Hardware Model: MacBookPro18,1
Process: Rhinoceros [9511]
Path: /Applications/Rhino 7.app/Contents/MacOS/Rhinoceros
Identifier: com.mcneel.rhinoceros.7
Version: 7.20 (7.20.22193.09002)
Code Type: X86-64 (Native)
Role: Default
Parent Process: launchd [1]
Coalition: com.mcneel.rhinoceros.7 [13168]Date/Time: 2022-07-16 19:11:34.8668 +0300
Launch Time: 2022-07-16 19:11:34.8242 +0300
OS Version: macOS 12.4 (21F79)
Release Type: User
Report Version: 104Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000001, 0x00007ff7fffb09c8
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: SIGNAL 5 Trace/BPT trap: 5
Terminating Process: exc handler [9511]Triggered by Thread: 0
Thread 0 Crashed:
0 runtime 0x7ff7fffb09c8 0x7ff7fff93000 + 121288
1 runtime 0x7ff7fffb03ac 0x7ff7fff93000 + 119724
2 runtime 0x7ff7fffa8140 0x7ff7fff93000 + 86336
3 runtime 0x7ff7fff96b60 0x7ff7fff93000 + 15200
4 dyld 0x2000f0000 ???Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x0000000000000003 x2: 0x000000000000003c x3: 0x000000000000002c
x4: 0x0000000000000303 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x00000000000003e0
x8: 0x00007ff7fffce000 x9: 0x0000000000000000 x10: 0x0000000000000000 x11: 0x00007ff7fffce8f4
x12: 0x0000000000000000 x13: 0x0000000000000039 x14: 0x00000001081b4374 x15: 0x00007ff7fffb6818
x16: 0xffffffffffffffe1 x17: 0x00007ff7fffbf6de x18: 0x00000003041fb08b x19: 0x00007ff7fffc42e1
x20: 0x00007ff7fffbeb9f x21: 0x0000000000000063 x22: 0x00007ff7fffbeb93 x23: 0x00000003041f9ff0
x24: 0x00000001081652e0 x25: 0x0000000000000248 x26: 0x0000000000000009 x27: 0x00000002001701b8
x28: 0x0000000000000001 fp: 0x00000003041f9fb0 lr: 0x00007ff7fffb09c0
sp: 0x00000003041f9f90 pc: 0x00007ff7fffb09c8 cpsr: 0x60001000
far: 0x00000003041f9fe8 esr: 0xf2000001 (Breakpoint) brk 1Binary Images:
0x7ff7fff93000 - 0x7ff7fffc2fff runtime () <0ee8ce32-639c-316a-9551-dab9a2e0c8a5> /usr/libexec/rosetta/runtime
0x2000f0000 - 0x20015bfff dyld () /usr/lib/dyldError Formulating Crash Report:
dyld_process_snapshot_get_shared_cache failedEOF
Full Report
{“app_name”:“Rhinoceros”,“timestamp”:“2022-07-16 19:11:34.00 +0300”,“app_version”:“7.20”,“slice_uuid”:“80bd4f71-905a-3eac-bb7e-14c398bbe0f7”,“build_version”:“7.20.22193.09002”,“platform”:0,“bundleID”:“com.mcneel.rhinoceros.7”,“share_with_app_devs”:1,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.4 (21F79)”,“incident_id”:“D66A7014-F68C-40DA-9F4D-EC99FC35647B”,“name”:“Rhinoceros”}
“uptime” : 7900,
“procLaunch” : “2022-07-16 19:11:34.8242 +0300”,
“procRole” : “Default”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro18,1”,
“procStartAbsTime” : 190135718928,
“coalitionID” : 13168,
“osVersion” : {
“train” : “macOS 12.4”,
“build” : “21F79”,
“releaseType” : “User”
“captureTime” : “2022-07-16 19:11:34.8668 +0300”,
“incident” : “D66A7014-F68C-40DA-9F4D-EC99FC35647B”,
“bug_type” : “309”,
“pid” : 9511,
“procExitAbsTime” : 190135999534,
“translated” : true,
“cpuType” : “X86-64”,
“procName” : “Rhinoceros”,
“procPath” : “/Applications/Rhino 7.app/Contents/MacOS/Rhinoceros”,
“bundleInfo” : {“CFBundleShortVersionString”:“7.20”,“CFBundleVersion”:“7.20.22193.09002”,“CFBundleIdentifier”:“com.mcneel.rhinoceros.7”},
“storeInfo” : {“deviceIdentifierForVendor”:“0910C0F1-9565-51AD-8140-C6C475F673A0”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.mcneel.rhinoceros.7”,
“crashReporterKey” : “000410E0-F39B-2EAC-7243-E254033FC785”,
“wakeTime” : 3734,
“sleepWakeUUID” : “B447B223-4291-4800-B253-03DC5472AF2F”,
“sip” : “enabled”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0x00007ff7fffb09c8”,“rawCodes”:[1,140703128291784],“type”:“EXC_BREAKPOINT”,“signal”:“SIGTRAP”},
“termination” : {“flags”:0,“code”:5,“namespace”:“SIGNAL”,“indicator”:“Trace/BPT trap: 5”,“byProc”:“exc handler”,“byPid”:9511},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:139210,“threadState”:{“x”:[{“value”:0},{“value”:3},{“value”:60},{“value”:44},{“value”:771},{“value”:0},{“value”:0},{“value”:992},{“value”:140703128412160},{“value”:0},{“value”:0},{“value”:140703128414452,“symbolLocation”:140,“symbol”:“crashreporter_info”},{“value”:0},{“value”:57},{“value”:4430971764},{“value”:140703128315928},{“value”:18446744073709551585},{“value”:140703128352478},{“value”:12954087563},{“value”:140703128371937},{“value”:140703128349599},{“value”:99},{“value”:140703128349587},{“value”:12954083312},{“value”:4430648032},{“value”:584},{“value”:9},{“value”:8591442360,“symbolLocation”:0,“symbol”:“dyld_all_image_infos”},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:140703128291776},“cpsr”:{“value”:1610616832},“fp”:{“value”:12954083248},“sp”:{“value”:12954083216},“esr”:{“value”:4060086273,“description”:“(Breakpoint) brk 1”},“pc”:{“value”:140703128291784,“matchesCrashFrame”:1},“far”:{“value”:12954083304}},“frames”:[{“imageOffset”:121288,“imageIndex”:0},{“imageOffset”:119724,“imageIndex”:0},{“imageOffset”:86336,“imageIndex”:0},{“imageOffset”:15200,“imageIndex”:0},{“imageOffset”:0,“imageIndex”:1}]}],
“usedImages” : [
“source” : “P”,
“arch” : “arm64”,
“base” : 140703128170496,
“size” : 196608,
“uuid” : “0ee8ce32-639c-316a-9551-dab9a2e0c8a5”,
“path” : “/usr/libexec/rosetta/runtime”,
“name” : “runtime”
“source” : “P”,
“arch” : “x86_64”,
“base” : 8590917632,
“size” : 442368,
“uuid” : “b70ce1ec-b902-3852-8268-05de00bfa8d5”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“vmSummary” : “ReadOnly portion of Libraries: Total=840K resident=0K(0%) swapped_out_or_unallocated=840K(100%)\nWritable regions: Total=136.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=136.1M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nRosetta Generic 8K 2 \nRosetta IndirectBranch (reserved) 32K 1 reserved VM address space (unallocated)\nRosetta JIT 128.0M 1 \nSTACK GUARD 56.0M 1 \nStack 8176K 1 \nVM_ALLOCATE (reserved) 36K 4 reserved VM address space (unallocated)\n__DATA 80K 3 \n__DATA_CONST 80K 1 \n__LINKEDIT 240K 4 \n__TEXT 624K 2 \nmapped file 1384K 10 \n=========== ======= ======= \nTOTAL 194.4M 30 \nTOTAL, minus reserved VM space 194.3M 30 \n”,
“legacyInfo” : {
“threadTriggered” : {}
“trialInfo” : {
“rollouts” : [
“rolloutId” : “607844aa04477260f58a8077”,
“factorPackIds” : {
“SIRI_MORPHUN_ASSETS” : “6103050cbfe6dc472e1c982a”
“deploymentId” : 240000066
“rolloutId” : “6112e14f37f5d11121dcd519”,
“factorPackIds” : {
“SIRI_TEXT_TO_SPEECH” : “62c4376c87beda2658c8f47d”
“deploymentId” : 240000178
“experiments” : []
“reportNotes” : [
“dyld_process_snapshot_get_shared_cache failed”
}Model: MacBookPro18,1, BootROM 8419.0.113.0.1, proc 10:8:2 processors, 16 GB, SMC
Graphics: Apple M1 Pro, Apple M1 Pro, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5
AirPort: Wi-Fi, wl0: Apr 6 2022 05:55:54 version 20.90.45.0.8.7.118 FWID 01-e7138ff2
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: USB Receiver
Thunderbolt Bus: MacBook Pro, Apple Inc.
