setting up a brand new MacBook Pro, and my Rhino 5 instantly crashes the second I try to open it. So I downloaded rhino 7 to do the trial of it, and am having the exact same problem. Any suggestions?
here is the error message I’m getting :
Translated Report (Full Report Below)
Incident Identifier: 1F403924-6797-4ADA-BD32-42D48F583FB5
CrashReporter Key: 249FF218-30BA-FD64-F8D7-F49ACB4CD46D
Hardware Model: MacBookPro18,2
Process: Rhinoceros [48238]
Path: /Applications/Rhino 7.app/Contents/MacOS/Rhinoceros
Identifier: com.mcneel.rhinoceros.7
Version: 7.19 (7.19.22165.13002)
Code Type: X86-64 (Native)
Role: Default
Parent Process: launchd [1]
Coalition: com.mcneel.rhinoceros.7 [26837]
Date/Time: 2022-06-29 13:18:15.6499 -0400
Launch Time: 2022-06-29 13:18:15.6106 -0400
OS Version: macOS 12.2.1 (21D62)
Release Type: User
Report Version: 104
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000001, 0x00007ff7ffce7af8
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: SIGNAL 5 Trace/BPT trap: 5
Terminating Process: exc handler [48238]
Triggered by Thread: 0
Application Specific Information:
rosetta error: /var/db/oah/279281327407104_279281327407104/a98b0093621e905525e161100e56cc508f70a220cf4d53b8d30951fe32b014ca/Rhinoceros.aot: attachment of code signature supplement failed: 1
Thread 0 Crashed:
0 runtime 0x7ff7ffce7af8 0x7ff7ffccb000 + 117496
1 runtime 0x7ff7ffce7b40 0x7ff7ffccb000 + 117568
2 runtime 0x7ff7ffcde440 0x7ff7ffccb000 + 78912
3 runtime 0x7ff7ffcdf518 0x7ff7ffccb000 + 83224
4 runtime 0x7ff7ffcdec94 0x7ff7ffccb000 + 81044
5 runtime 0x7ff7ffccea80 0x7ff7ffccb000 + 14976
6 ??? 0x3 ???
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x0000000000000003 x2: 0x000000000000003c x3: 0x000000000000002c
x4: 0x0000000000000303 x5: 0x0000000000000000 x6: 0x0000000000000000 x7: 0x0000000000000000
x8: 0x00007ff7ffd06000 x9: 0x0000000000000000 x10: 0x0000000000000000 x11: 0x00007ff7ffd0694d
x12: 0x0000000000000000 x13: 0x0000000000000000 x14: 0x0000000000000000 x15: 0x00007ff7ffcee828
x16: 0xffffffffffffffe1 x17: 0x00000000ffffffff x18: 0x000000030e33006b x19: 0x00007ff7ffcfc2e1
x20: 0x000000030e330720 x21: 0x0000000104fc2000 x22: 0x0000000000000004 x23: 0x0000000104fc2000
x24: 0x0000000000000003 x25: 0x0000000000000001 x26: 0x000000030e32fb80 x27: 0x00000002053cb1b8
x28: 0x000000030e338950 fp: 0x000000030e32e960 lr: 0x00007ff7ffce7af0
sp: 0x000000030e32e940 pc: 0x00007ff7ffce7af8 cpsr: 0x60001000
far: 0x000000030e32e978 esr: 0xf2000001 (Breakpoint) brk 1
Binary Images:
0x7ff7ffccb000 - 0x7ff7ffcfafff runtime () /usr/libexec/rosetta/runtime
0x0 - 0xffffffffffffffff ??? () <00000000-0000-0000-0000-000000000000> ???
Error Formulating Crash Report:
dyld_process_snapshot_get_shared_cache failed
EOF
Full Report
{“app_name”:“Rhinoceros”,“timestamp”:“2022-06-29 13:18:15.00 -0400”,“app_version”:“7.19”,“slice_uuid”:“80bd4f71-905a-3eac-bb7e-14c398bbe0f7”,“build_version”:“7.19.22165.13002”,“platform”:0,“bundleID”:“com.mcneel.rhinoceros.7”,“share_with_app_devs”:1,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.2.1 (21D62)”,“incident_id”:“1F403924-6797-4ADA-BD32-42D48F583FB5”,“name”:“Rhinoceros”}
“uptime” : 240000,
“procLaunch” : “2022-06-29 13:18:15.6106 -0400”,
“procRole” : “Default”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro18,2”,
“procStartAbsTime” : 5770067789977,
“coalitionID” : 26837,
“osVersion” : {
“train” : “macOS 12.2.1”,
“build” : “21D62”,
“releaseType” : “User”
“captureTime” : “2022-06-29 13:18:15.6499 -0400”,
“incident” : “1F403924-6797-4ADA-BD32-42D48F583FB5”,
“bug_type” : “309”,
“pid” : 48238,
“procExitAbsTime” : 5770068167290,
“translated” : true,
“cpuType” : “X86-64”,
“procName” : “Rhinoceros”,
“procPath” : “/Applications/Rhino 7.app/Contents/MacOS/Rhinoceros”,
“bundleInfo” : {“CFBundleShortVersionString”:“7.19”,“CFBundleVersion”:“7.19.22165.13002”,“CFBundleIdentifier”:“com.mcneel.rhinoceros.7”},
“storeInfo” : {“deviceIdentifierForVendor”:“2EC283D1-CD5B-5B4C-A0F1-509DC62189D5”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.mcneel.rhinoceros.7”,
“crashReporterKey” : “249FF218-30BA-FD64-F8D7-F49ACB4CD46D”,
“wakeTime” : 1371,
“sleepWakeUUID” : “60A09F80-2540-4827-AFDC-02285616C626”,
“sip” : “enabled”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0x00007ff7ffce7af8”,“rawCodes”:[1,140703125371640],“type”:“EXC_BREAKPOINT”,“signal”:“SIGTRAP”},
“termination” : {“flags”:0,“code”:5,“namespace”:“SIGNAL”,“indicator”:“Trace/BPT trap: 5”,“byProc”:“exc handler”,“byPid”:48238},
“asi” : {“runtime”:[“rosetta error: /var/db/oah/279281327407104_279281327407104/a98b0093621e905525e161100e56cc508f70a220cf4d53b8d30951fe32b014ca/Rhinoceros.aot: attachment of code signature supplement failed: 1”]},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:3489686,“threadState”:{“x”:[{“value”:0},{“value”:3},{“value”:60},{“value”:44},{“value”:771},{“value”:0},{“value”:0},{“value”:0},{“value”:140703125495808},{“value”:0},{“value”:0},{“value”:140703125498189,“symbolLocation”:197,“symbol”:“crashreporter_info”},{“value”:0},{“value”:0},{“value”:0},{“value”:140703125399592},{“value”:18446744073709551585},{“value”:4294967295},{“value”:13123125355},{“value”:140703125455585},{“value”:13123127072},{“value”:4378599424},{“value”:4},{“value”:4378599424},{“value”:3},{“value”:1},{“value”:13123124096},{“value”:8677798328,“symbolLocation”:0,“symbol”:“dyld_all_image_infos”},{“value”:13123160400}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:140703125371632},“cpsr”:{“value”:1610616832},“fp”:{“value”:13123119456},“sp”:{“value”:13123119424},“esr”:{“value”:4060086273,“description”:“(Breakpoint) brk 1”},“pc”:{“value”:140703125371640,“matchesCrashFrame”:1},“far”:{“value”:13123119480}},“frames”:[{“imageOffset”:117496,“imageIndex”:0},{“imageOffset”:117568,“imageIndex”:0},{“imageOffset”:78912,“imageIndex”:0},{“imageOffset”:83224,“imageIndex”:0},{“imageOffset”:81044,“imageIndex”:0},{“imageOffset”:14976,“imageIndex”:0},{“imageOffset”:3,“imageIndex”:1}]}],
“usedImages” : [
“source” : “P”,
“arch” : “arm64”,
“base” : 140703125254144,
“size” : 196608,
“uuid” : “faca02c7-0a4c-3629-a746-55ddcfee9116”,
“path” : “/usr/libexec/rosetta/runtime”,
“name” : “runtime”
“size” : 0,
“source” : “A”,
“base” : 0,
“uuid” : “00000000-0000-0000-0000-000000000000”
“vmSummary” : “ReadOnly portion of Libraries: Total=840K resident=0K(0%) swapped_out_or_unallocated=840K(100%)\nWritable regions: Total=21.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=21.6M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nSTACK GUARD 56.0M 1 \nStack 8176K 1 \nVM_ALLOCATE 13.1M 4 \nVM_ALLOCATE (reserved) 464K 2 reserved VM address space (unallocated)\n__DATA 80K 3 \n__DATA_CONST 80K 1 \n__LINKEDIT 240K 4 \n__TEXT 624K 2 \nmapped file 6.0G 28 \n=========== ======= ======= \nTOTAL 6.0G 46 \nTOTAL, minus reserved VM space 6.0G 46 \n”,
“legacyInfo” : {
“threadTriggered” : {
“trialInfo” : {
“rollouts” : [
“rolloutId” : “601d9415f79519000ccd4b69”,
“factorPackIds” : {
“SIRI_TEXT_TO_SPEECH” : “622657ce37186c771d5404ad”
“deploymentId” : 240000416
“rolloutId” : “607844aa04477260f58a8077”,
“factorPackIds” : {
“SIRI_MORPHUN_ASSETS” : “6103050cbfe6dc472e1c982a”
“deploymentId” : 240000066
“rolloutId” : “5fb4245a1bbfe8005e33a1e1”,
“factorPackIds” : {
"deploymentId" : 240000015
"rolloutId" : "602ad4dac86151000cf27e46",
"factorPackIds" : {
"SIRI_DICTATION_ASSETS" : "61fb0e87c773c43cde3bb80e"
"deploymentId" : 240000305
"rolloutId" : "60da5e84ab0ca017dace9abf",
"factorPackIds" : {
"deploymentId" : 240000008
"rolloutId" : "5fc94383418129005b4e9ae0",
"factorPackIds" : {
"deploymentId" : 240000385
"rolloutId" : "5ffde50ce2aacd000d47a95f",
"factorPackIds" : {
"deploymentId" : 240000167
“experiments” : [
“reportNotes” : [
“dyld_process_snapshot_get_shared_cache failed”
Model: MacBookPro18,2, BootROM 7429.81.3, proc 10:8:2 processors, 64 GB, SMC
Graphics: Apple M1 Max, Apple M1 Max, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5
AirPort: Wi-Fi, wl0: Dec 13 2021 17:12:34 version 20.10.853.31.8.7.109 FWID 01-804e92d8
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: Rugged THB USB-C
Thunderbolt Bus: MacBook Pro, Apple Inc.
