Ok. What I really cannot do is cutting the part of a closed curve above the z=0 plane. The general question here is: Is it possible to cut somehow a part of a closed curve wherever?
As simple as this. I want to cut several closed curves like this one, from z=0 upwards. I can use the Trim command with surfaces, but I don’t know how to handle these closed curves.
Hi Miguel- in front or right, start Line, type in 0 as the start point, set BothSides and then use Ortho to set the line exactly horizontal in that view. Use this line to Trim the rectangle, making sure that ApparentIntersections=Yes as a rule.
If you have a lot of curves and they all need to be trimmed at the same time to the same line, use a crossing window to select the sides of all the curves to trim off at one time. Does that get at what you need? See also the CutPlane command for making a trimming plane- Select all curves, start CutPlane in an elevation view and use Ortho to keep the plane horizontal to the view. A plane cutting through all selected objects will be created.
(BTW, in V6, you will be able to trim/split with the current cplane.)
