hey guys, i am searching for a way to get a trimmed surface from a closed planar polycurve (in my case a polygon, only straight edges). is there a dedicated method or will i have to tinker with breps? if so, what’s the easiest way to achieve that?
best, heinz.
Probably the best way is to:
thanks, jordy! this solution might be a bit expensive, though…
Hi Heinz,
Use Rhino.Geometry.Brep.CreatePlanarBreps.
thanks a lot, dale! works now. all the best from vienna!
