If you run this short script, a file selection window will pop up. If you cancel this window, then Rhino crashes after a few seconds.
Is this a bug or should I be doing this another way? The crash does not occur when selecting only a single file and cancelling the file selection window using this code:
from rhinoscriptsyntax import OpenFileName
filtr = 'Text Files (*.txt)|*.txt| XYZ Color files (*.xyz)|*.xyz|pts Files (.pts)|*.pts||'
strPath = OpenFileName('XYZRGB file to import', filtr)
Thanks for your help with this issue. I stumbled across its existence when debugging my Python/C++ script. I would compile the C++ in Debug mode and then, on the Python side, I would launch the script without remembering to select the Debug DLL version at the top of the script. I would remember this just as the files selection menu would come up and try to cancel so I could go back to fix this without having to wait the 30 sec it takes for the script to import and display a 21GB pointcloud. But oops Rhino would crash and I would have to start all over.
