I just downloaded the new Rhino Mac (wip_20140630). After installing IronPython (python20140630) I can run scripts, but when I try to generate a textile via the python script it does not create the txt file. I also don’t get any errors and I know that the script is woking correctly. Any ideas on how to fix this?
Thanks!
Do you have a sample to test?
–Mitch
#Export the coordinates of point and point cloud objects to a text file.
def ExportPoints():
#Get the points to export
objectIds = rs.GetObjects("Select Points",rs.filter.point | rs.filter.pointcloud,True,True)
if( objectIds==None ): return
#Get the filename to create
filter = "Text File (*.txt)|*.txt|All Files (*.*)|*.*||"
filename = rs.SaveFileName("Save point coordinates as", filter)
if( filename==None ): return
file = open(filename, "w")
for id in objectIds:
#process point clouds
if( rs.IsPointCloud(id) ):
points = rs.PointCloudPoints(id)
for pt in points:
file.write(str(pt))
file.write("\n")
elif( rs.IsPoint(id) ):
point = rs.PointCoordinates(id)
file.write(str(point))
file.write("\n")
file.close()
# Here we check to see if this file is being executed as the "main" python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
if( __name__ == '__main__' ):
ExportPoints()
Yep, looks like there is a problem here, I have been able to determine that rs.SaveFileName is returning None, thus the script simply exits before anything is done…
Edit: I tried to hard code a path to a file in the script, but honestly it’s still a mystery to me how you specify an absolute file path in Mac, nothing I tried worked.
–Mitch
Do you know if there is any way to download the IronPython for wip_20140610? It used to work fine then…
Thanks,
Kai
No, I don’t…
I managed to succeed in writing a file with a name collected using rs.GetString() in a user-selected folder with rs.BrowseForFolder(), so it’s just rs.SaveFileName() that’s not working.
import os
def ExportPoints():
#filter = "Text File (*.txt)|*.txt|All Files (*.*)|*.*||"
#filename = rs.SaveFileName("Save point coordinates as", filter)
#if( filename==None ): #return
folder=rs.BrowseForFolder()
fName=rs.GetString("File name?")
if not fName: return
filename=os.path.join(folder,fName+".txt")
for pt in points:
file.write(str(pt)+"\n")
file.write(str(point)+"\n")
file.close()
ExportPoints()
Great - thanks! That helped for now…
kai
Now it also seems like the rs.OpenFileName() is not working either. Any suggestions on how to fix that?
here is my python and a txt file that I’m trying to run:
# Import points from a text file
counter = 0
def ImportPoints():
#prompt the user for a file to import
print 'init.txt file'
filter = "Text file (*.txt)|*.txt|All Files (*.*)|*.*||"
filename = rs.OpenFileName("Open Point File", filter)
if not filename: return
#read each line from the file
file = open(filename, "r")
contents = file.readlines()
file.close()
# local helper function
def __point_from_string(text):
#print "gr"
#print text
items = text.split(" ") #.strip("()\n")
if items[0]=="v":
#counter+=1
x = float(items[1])
y = float(items[2])
z = float(items[3])
rs.AddPoint (x,y,z)
print 'x = '+str(x)
return x, y, z
contents = [__point_from_string(line) for line in contents]
# Check to see if this file is being executed as the "main" python
if( __name__ == "__main__" ):
ImportPoints()
test.txt (1004.8 KB)
I am working on a fix for this right now. I should have a new python build available within an hour
Thanks a lot. It’s working well again.
Kai
Hi steve,
I am facing this issue as well, can I get the build containing this fix somewhere?
thanks ad best regards,
Tim
The latest build of Mac Rhino can always be downloaded at
http://www.rhino3d.com/download/rhino-for-mac/5.0/wip
There is no separate download for python support anymore; that feature is now included in Rhino for Mac
Hi Steve,
Thanks for the quick response, I have installed this already (details below). However rs.SaveFileName() always returns “None”. Similar to what Helvetosaur described. As you have made a fix for this, it seems ‘my’ Rhino is not using the correct version of python. Do you have any suggestions?
best regards,
Tim
Software versions
Rhinoceros version: 5.0 WIPVersionSuffix (5A683)
IronPython version: 5.1.2014.1006
Language: nl (MacOS default)
OS X version: Version 10.10.1 (Build 14B25)
Ok, I’ll have to take a look and see if I can repeat this.
i have a little piece of code from @Helvetosaur which gives a list of subdirectories for scriptcontext… it uses rs.SaveFileName and it works for me in the latest mac rhino release.
import scriptcontext as sc
def ExportClassDirectory(direc):
filename = rs.SaveFileName("Save directory as", filter)
namext=filename.split("\\")
name=namext[-1].split(".")
file=open(filename,"w")
file.write(name[0]+"\n\n")
for item in direc:
file.write(item+"\n")
file.close()
direc=dir(sc.doc)
does the above script work for you?
(it should create a .txt file)
i think that’s the correct or current version of ironpython in mac rhino… (which is a different thing than the current python which ships with osx… that being Python 2.7.6
thank you Jeff, but as rs.SaveFileName still returns “None”. the script exits at the next line.
however “python -V” in terminal returns “Python 2.7.8”. could this version be conflicting with 2.7.6?
Best regards,
tim
do you mean that exact script i posted just above fails for you in mac rhino?
if so, then yeah, that’s odd… i just tried it again to be certain and it’s definitely working here…
software wise, it looks like we’re running the same stuff:
Software versions
Language: en (MacOS default)
the difference is that i have python 2.7.6 and you have 2.7.8…
whether or not this is a source of conflict is beyond my knowledge
(although i have seen instances around here of people using older versions of python than me (2.7.2 which ships with mountainLion) having issues)
edit
as another example:
if i run this script:
filename = rs.SaveFileName()
rs.MessageBox(filename)
i’m first prompted with an osx save dialog…
then upon clicking ‘save’, i get the rhino message box:
edit2 @timcastelijn
i also see we’re running different languages (you=nl me=en)…
but again, whether or not this is causing a difference with rs.SaveFileName is beyond me
Do you see the user interface for the save dialog and then None is returned no matter what?
hi Steve,
that is correct. selecting a file to save, or open always returns None. Regardless whether I proceed or escape. I have isolated the issue in the script below.
# import rhinoscriptsytax
# Check to see if this file is being executed as the "main" python script
filename = rs.SaveFileName ("Save", "Toolpath Files (*.nc)|*.nc||")
print(filename) # returns None, after giving filename
filename2 = rs.OpenFileName ("Save", "Toolpath Files (*.nc)|*.nc||")
print(filename2) # returns None after selecting file
rs.MessageBox("check function") # throws error -> Message: ShowMessageBox() takes at most 4 arguments (5 given)
Thanks, I think I know what is going on. I’ll probably have a few more questions as I work through this:)
