For example, I simply created a curtain wall in Revit without setting the curtain wall grid division, and then imported the curtain wall dividing line of the building facade in the CAD drawing into Revit. Can I use the rhino inside revit plug-in? The curtain wall dividing line of the CAD elevation drawing in revit is used to cut the curtain wall components created by Revit, and finally get the Revit curtain wall components of the specified grid division, and then use these divided curtain wall grids to set the curtain wall panel and curtain wall crossbar and vertical club?
So you mean something like this?
Thank you very much for your suggestion, it gave me a lot of inspiration
